Right tank needs pulling and repaired. What is best technique in cutting access hole in baffle once I've located the area in need repairing. Pretty confident it is not in the access or fuel sender area. If a specific tool, please share brand, source etc.
I cut a rectangular hole in the rear baffle to give me the most room to work. I first used a step bit and drilled a 1/2” hole in the corners and then used a dremel with a metal wheel and cut the lines connecting the corners.
Weep no more removes the entire rear baffel, does their magic and rivets it back on. This probably isn't the best option if you just have one or two leaks.
Most HVAC distributors, home depot, amazon have this tool: It's a tool that you can use with your cordless drill to cut a round hole in sheetmetal, adjustable and bits are replaceable. Malco is a prominent HVAC tool supplier. HC1S.
The fixed size hole saws are great, But, the Klein hole cutter is really the tool to cut any size hole you want.
Works great. Same mess to clean up though.
Art
Klein Tools 89552 not suited for tank leak repair.
I bought the Klein Tools 89552 recommended above. The minimum size hole it can cut without colliding with the Z brackets is 6 inches. This is too big for the cover plates supplied by Vans for this repair Part No T-412.
Next, I'll try using a hole saw in reverse. Fly cutters are too unstable for my liking.
I thought the fly-cutter would be a disaster but DanH recommended it and I tried it. Sharpened the cutter on a stone, cordless drill near zero RPM, like cutting it with a knife. Perfect cut, no drama, minimal chips in the tank after.
