amaris
The clevis end of the weldment to attach to the actuator is pretty much centered in the channel. But the rod bearing end of the actuator is over about 3/8" off which would require twisting the whole actuator to get it to line up with the clevis, which I don't think is correct.
Is the solution to create a longer spacer to move the whole actuator more inboard?
Thanks for any input.
How long is the spacer F-766D now?
