bobg56
I'm in the process of replacing the stand off but can't find the torque of the bolts attaching it to the firewall, I've looked and looked no joy...anyone know what it is?...thanks
Did you look in section 5 for the normal torque for those bolts? I don’t recall if they are different
I did not check section 5 but figured there should be a specific value, the ISO mounts are listed at 160-190 inch pounds but nothing for the firewall mount, its a 3/8" bolt.
No special torque mentioned, so standard -6 torque -- 160 in/lbs. then continue as needed up to 190 in/lbs to align the hole in the bolt to the nut castellations so you can fit in the cotter pin. (All according to my old original KAIs..)
I checked the info on the SB and it just says to re install so I'll use standard of 160-190....thanks guys
