anybody have the dimensions of these washers? They are used to attach the ailerons and the aileron pushrods. I am not exactly sure which ones they are.
These are important parts. They are larger than the rod ends, so if a rod end bearing actually came apart these washers keep the control linkage from coming completely apart.
You may want to consider replacing those zinc plated Z3 washers wherever they are called for with cadium plated AN 970 washers. The zinc ones will corrode over time.
