I put the big “Experimental” sticker high up on the back panel of the RV-6’s baggage compartment. That is a common location for it.
I’m trying to figure out where to put the one on the -10. Is there a common location for those on the -10?
Probably based upon the inspector. I put mine high on the baggage bulkhead adn the FSDO guy had no issue with it, though I did have the warning label on the panel. I have seen some on the top inside of the door, visible when open, and some on the wing spar cover.
Larry
