WingedFrog
The more I progress in section 31, the more I find steps that I have to skip because the work involved will have to be changed for Skyview. I am beginning to be concerned by the number of loose ends wiring that I will be left with. I also have this problem with the wings terminal blocks that will be replaced with connectors per VANs facebook presention but this involves fewer wires. Of course, one option would be to follow blindly (or should I say blissfully?) the instructions and undo what needs to be reworked later but I hate to waste good parts as well as my time. Depending on how VANs will document the Skyview installation (as a retrofit vs as an all new equipment for a blank slate) my only option might be to follow current instructions. Any suggestions/ideas from you guys who are in the same situation?
