azflyer21
I asked FltPlan.com to setup the W&B for the RV14A, I sent them the Quick Reference data from Van's earlier today and it is now setup. Log in and under tools select Weight & Balance, set up your aircraft by selecting the Experimental category then select RV14A. Try out the calculations.
Looks decent; thanks for arranging that!
I changed the labels slightly and added a separate line for passenger weight, but it should work nicely. I usually do my W&B calculations directly in Garmin Pilot, but this might alter my workflow over time.
