flion
I'm stuck. With a backup alternator on the vacuum pad, there's no room to install a UMA transducer or right angle adapter. And I can find no source of extension cables. But the vtach transducer from Van's can attach to a regular tach cable as an extension but I can't get a data sheet on it. Has anyone used one of this with a Garmin EFIS? If so, can you share some info on it?
