I have my power line for the landing lights go from the VPX to a terminal block, from there a single wire goes out each wing, at the wing tip I split it into two and attached it to both 75w bulbs. I also buttspliced the grounds of each light together and ran a single wire to the outboard rib which I secured with a ring terminal on a nutplate. When I turn on the landing lights which have a 15a breaker, they don't come on because the VPX is tripping them. Here is where I'm lost. As begin trouble shooting, the wires check out and are not grounded. If I disconnect one light at the wingtip, the other light will turn on. All four lights work individually this way so I know its not the bulbs. Then I put a single light from each wingtip on one power wire at the terminal block and they both came on drawing 11.24 amps. So can anyone tell me why I can power two lights in opposite wingtips but I cannot power two lights in the same wingtip. Thanks,
Nick
Nick
