jumbo_flyer
Member
I would like to monitor the Power-Safe Back-up Battery output via the VPX-pro (J2-12). The battery has a monitor charge output (pin 4). The VPX instructions require a 1K Ohm, 1 watt resistor inline from battery. Does someone have a similar configuration that can advise? Can I use the built-in charge output or do I have to split the output, 1 to vpx and the other to master switch?
FM
