A confusing subject...
Eric, this topic comes up now and then on the board. Over the years, airspeeds have crept up among these airplanes for a myriad of reasons. A few instances of flutter have been encountered, none fatal as far as I know. Another thread on this subject - which started a fire storm - is here:
http://www.vansairforce.com/community/showthread.php?t=41255
A flutter incident was once reprinted in the RVator; the same issue also contained an article talking about the Never Exceed speed for our airplanes. In that article, V_ne was technically described and related to True airspeed.
Even though that's a correct association (V_ne and TAS), general aviation aircraft are *supposed* to be designed around indicated airspeed limits. Hence, we place a red line on our
airspeed indicator at V_ne. Its a fixed number on the dial, vs TAS which is altitude and temperature dependent. This is dictated by FAR, although not technically applicable to us since we're experimental aircraft.
To answer your question, MY GUESS is that flutter in the RV4/6/7, and 8 is probably restricted to the elevator surfaces. Several design factors contribute to increased flutter susceptibility:
- Relatively large, flat aluminum skins. These skins deflect easily under load, and therefore could buzz if pressed by a fast enough airflow.
- Using rod ends for hinges: We get adjustable hinge points with this scheme, but at the expense of a good stiff structure. IMHO, its not a great way to hinge a control surface.
- All mass balance placed at the tip of each elevator. With all the mass at the tip, the reaction forces are driven into the outboard elevator hinge, which then transfers those loads into the outboard horizontal stab. And, as you may guess, the most outboard portion of the structure is also where we get the most deflection.
All that adds up, in my view, to control surface flutter in the elevators. Not structural flutter (that's where the entire horizontal stabilizer gets into the act). Your supposition about the skin fluttering is probably correct, but it would be felt as a buzz at high frequency, not a shake in the stick.
At any rate, now that we know the limitation IS there, I'd keep an eye on the TAS's but still mark V_ne as a red line on the airspeed indicator, as required by Vans.
... and make sure you put those "rod-end-hinges" in tight
