Vision Microsystems lighting
Thanks. I suspect the display is lcd but can't find documentation as to exactly what it is. It is I believe designed to be visible in all lighting conditions, but is quite dim. I really do not fly at night, but daytime viewing regardless of sun angle is a problem. I have thought about a mini spot from ACS but with a side opening canopy I haven't found a good mounting site. The eyeball light is a good thought, but I'm not sure it would be bright enough to do the job. I've also thought about the led strips.
