F1 Rocket
I?m in the process of updating the avionics in my Rocket. I?d like to add a forward and rearward looking camera that will display via the Garmin 3GX system. Does anyone know of a video feed switch that can be used to switch between cameras?
What kind of video? If it's plain old composite (coax with a single pin in the middle, that looks like old stereo audio connectors), then almost any coax switch will work. Even the old A/B switches that came with the original video games will work, if you use RCA>F adapters.
https://www.google.com/search?q=composite+video+a/b++switch&source=lnms&sa=X&ved=0ahUKEwjus4Gf0OThAhUhU98KHSPmD7AQ_AUI-wEoAA&biw=1678&bih=947
https://www.google.com/search?q=rf+...5l3j69i60l2.3815j0j7&sourceid=chrome&ie=UTF-8
https://www.google.com/search?q=rca+to+f+adapter&oq=rca+to+f+adapter&aqs=chrome.0.0l5.4778j0j7&sourceid=chrome&ie=UTF-8
The input to the G3X is just composite. Search amazon for "composite video switch", tons of options.
Cameras
What cameras do you plan to use? I messed with this idea using a GoPro but I'd like to get a legit bullet camera installed.
I?ll be watching this thread as I, too, would be interested in a real bullet camera attached to a central digital recorder. Even though the GoPro and Garmin cameras have become smaller in the last 5 years, it seems to me that a camera only solution at the mounting point would be easier to incorporate into a permanent mounting.
video switch
This might work for you for the video switching: https://catalog.pac-audio.com/catalog/video-integration/vs41
You could either use a two way switch (ON-ON) for two inputs or even a three way switch (ON-ON-ON) for three video inputs. Just wire it up so the triggers go to ground and then that's the video you pass on to the G3X. An NKK M2024SS1W01 is a nice, small, 3-way switch that would work for that. Maybe, a forward, side, and rear view. An NKK M2022SS1W01 would work for the 2-way switch.
I hope this helps.
Jeff
