Flyyak
Friend
Trying to configure a G3X Touch. I have a RV7 with Hartzel blended airfoil and I0360. I use 83 as best glide. If you have this setup, what are you using for Vg and Vg sink rate to configure your G3X touch
Do some searching here, as many have posted their test results. Seems most find the sink rate for the 4,6,7,8 is between 8.5 and 10:1 at best glide speed, which also seems to vary a bit across testers. I use 87 kts / 100 mph for my 6A.
