I know many people fly on top of a solid overcast without an IFR rating. I am just curious how most determine the cut off point, it is all about risk management.
Do you only go if the ceiling is above a certain height?
Do you always have approach plates just in case of an emergency?
Do you just fly on top and never worry about the fan quitting?
Are you comfortable flying over a layer that is low IFR on the bottom?
What about between layers, at what point do you loose your comfort level?
If the base is fairly high and you are out of the bumps it makes perfect sence, but if the bases are low IFR, should one be there in the first place without an IFR rating? If the fan quits with a low IFR below, the IFR rating won't be a tone of help if there is no airports around anyway
I am sure that some IFR pilots are more cautious on this than some VFR pilot, please don't take offense
Canada's rules are fairly strict on VFROTT and I am just curious how our southern pilots make decisions on this as you have much more freedom. Above is most often the most comfortable place to be, but some days the most comfortable place is on the ground.
