I have mufflers on mine and absolutely love them, you don't loose any power, I have plenty and the sound, who cares, I don't have to worry about noise abantment issues, I just go fly.
I care about the sound!!! I live under the airport pattern. What fun would it be, if I didn't know a Lycoming was flying over...........and looking up!
Yes, Subies, rotaries, and helicopters need mufflers, as the sound is annoying to start with.
L.Adamson --- RV6A
Vetterman sent me a set of mufflers to try out. I installed them today and I have to say, I really like them. I didn't notice any performance decrease. However, definitely quieter than the straight pipes. They are NOT silencers! So there is still the classic "RV Sound". Just the noise level in on 7 instead of 10. Living up here in WI the big question was "how does the heat work?" Well, I have only one of the 2 heat exchangers hooked up and the heat was rolling out when I applied it. I will hook up the 2nd heat exchanger at a later date.
It appears that to swap your straight pipes for the muffled pipes will cost you around $650, but if you buy them for your initial installation you will save a $150 or so. Call Larry for an accurate quote.
In my opinion they are definitely worth it. I have been around planes a long time and I want to save my hearing for as long as possible. The mufflers do a good job toning the sound down, but not so much to make it sound like a Cessna.
It took me 4 hours to retrofit the mufflers and I took my time. I would think the average builder could retrofit in or about the same amount of time. The initial installation would take no longer than the straight pipe.
I brought the pipes to my EAA Chapter meeting last night. Although there were mixed feelings about "mufflers" most admired the quality construction and they were a bit of a novelty. (funny how we'll admire a set of mufflers like some would admire a piece of jewelry).
If you are interesting in a set call Larry Vetterman, his website is a bit old school and you won't find much help there. Just call and he will set you up.
Tony, the mounting hardware on my system appears to be somewhat different than on previous Vetterman installations, where all mounting hardware connected to the engine. Larry's setup as supplied to me had outer struts connecting to the motor mount, with inner struts going up to the aft edge of the crankcase at the oil pan bolts (the latter being similar to non-muffled Vetterman systems I've seen).
I'm a little leery of this because it seems that the struts connected to the motor mount will cause a lot of shifting and tugging on startup/shutdown. But I haven't started the engine yet, let alone flown with it. Is yours the same? Opinions?
Thanks!
Update on Vetterman mufflers.
I have about 10-15 hours on the mufflers now. I have to say, it's much quieter. I have had lot's of people fly in the plane before and after the installation and everyone agrees it's not nearly as noisy. Again I need to say that they only muffle the sound and do NOT silence it. The plane still sounds like and "RV" and I have not noticed ANY performance impairment.
I am still trying to figure out some collateral effects of the installation. Namely, my EGT's and CHT's seem to be more in line with each other. I am afraid to speculate but I wonder if it is possible that the minor restriction in the pipes has balanced the flow through my o-320 cylinders. Additionally, the "rumble" that I had beneath my feet has all but diminished.
Personally, I would not go with out them. They add a bit of cost to a FWF package, but I think it's a very worthwhile investment. The comfort of flying without my ears ringing afterward is worth at least the cost of the installation.
Since I my mufflers were on loan from Vetterman, Larry contacted me and told me wanted them back. So, I refused and told him to take a hike! No, actually, I was happy to send him a check for them. There's no way I am taking them off the plane.
Good to hear... er, ah, read that. Since when I get mine flying I'll have no basis for comparison, it's nice to get your real-world report supporting my decision.
I take it that the muffler hangers are holding up fine so far?
