B Bart Well Known Member Aug 18, 2020 #1 I'm installing the Vetterman Exhaust this week. Can I get some pics of how folks did the hangers and the heater muff locations they chose. Most of the legacy blogs seem to have an older version that exit out the tunnel.
J jfisher Active Member Aug 20, 2020 #2 Right behind you in the Vetterman install. Check out MyRV14.com under Fall/Winer 2019 updates. Tim Olson took some great pics.
B Bart Well Known Member Aug 24, 2020 #3 Jim Thanks. I did indeed use Tim's updated pics to muddle through the process....it actually looks pretty good. If you need pics let me know.
S Stu Mclean Member Aug 24, 2020 #4 Hi Bart Have sent you a pm with email address if you could send pics that would be great Stewy
B Bart Well Known Member Aug 25, 2020 #5 Sent pics to both PM's...thanks for letting me know I'm not the only who is a visual learner!
