VP- 50 help needed
I have a Vertical Power vp-50 that the switch panel and its display went dead. The connections all appear to be good.The CU (control unit) has a yellow diode blinking a steady blink. I cannot find any reference to this light in any of vertical power manuals. My next task will to remove the cord that goes from the CU to the switch panel and check the contacts and ring the wires. Every thing worked 3 days ago, but this morning display and switches did nothing. If any one has a vp-50 or vp-100 that they removed I would be interested in buying it. Thanks Ron
