Hi,
If anybody has configured a Vertical Power PPS and VP-X with a Skyview system, I would be interested in knowing how you configured the output from the PPS to provide ammeter readings and low voltage readings. The PPS instructions have pinouts (see attached) from the PPS going to LEDs for battery or alternator faults and to ammeters for reading battery voltage or alternator output. But, I presume separate LEDs and ammeters are not necessary with the SV system.
Thanks for any help.
Scott
![PPS Wiring Pin Outs.jpg PPS Wiring Pin Outs.jpg](https://vansairforce.net/data/attachments/10/10983-8906c738da12ef6ada9d31b62440fa83.jpg)
Scott
