Bill.Peyton
After 12 years and 1500+ hours, I decided to upgrade my flap actuator to the newer product now provided by Van's. Not that the old one had failed, I just needed a project!
The installation was straight forward and the calibration with the Vertical power system was quick and easy. After flying with the new actuator for a couple of months, on day when deploying the flaps I get a "flap fault" displayed on the EFIS. I did a quick reset and didn't see it for another month or so. and then again a month later or so. I suspected that the built in potentiometer must have and issue, and that could be triggering the fault, but decided to do a little investigating. The VPX flap motor ECB current had been set to 5 amps. When I instrumented the motor I was able to see some instantaneous surges of almost 5 amps. The flaps were not under any load whatsoever. I suspect that in spite of the running current of the motor averaging around 1 amp, the surge current was tripping the electronic CB flagging a fault when in flight and under aerodynamic load.
Sounds like a simple fix. Wrong! Checking the latest IM for the VPX I find a note that limits the Flaps ECB to 5 amps for VPX units under S/N 1350. Mine is S/N 895. The VPX set up software has an available selection of 1-10 amps. The note says to contact them for an upgrade.
Anyone had a similar issue or sent in there unit for an upgrade?
