Did my first engine run today. All went well except I had no RPM reading. I'm using Vans tachometer transducer into my dynon. The tach trans takes power from the battery bus. After disconnecting the transducer wiring, I determined that I had no power to the red wire... I then found that the 2 amp fuse I had in there was blown. I put a 3 amp fuse in and tried spinning the tach trans with a drill... this blew the fuse again. I then put a 5 amp fuse in and the tachometer seems to work now (at least by spinning the transducer with my drill).
Question:
1) I can't seem to find any documentation about the current load of the tach trans. I'm not sure why i chose a 2Amp fuse to begin with. 5A seems pretty high though... how much should this transducer be drawing??
2) As others have found, you cannot tighten the transducer on the engine case too tightly or the key will push on the back plate and pop it off. I can only put mine on finger tight before this happens. Would there by any harm in using some blue loctite on this for security?
Question:
