lowandslo
Member
Only about 160 hours on it. Works great until it goes to zero. Works great next flight. Change the gauge or sender first? Anyone else already been through this? Thanks for any input.
Tach failure
During phase 1 I had a few of the vans gauges intermittently go off line. In the end, I took a closer look at the terminal crimps, grounding points, and tightness of the connections on the back side of the vans instruments. For the past 250 hrs, I haven't had any issues. Wiggle the wires and see if the tach gauge comes back on line.
As a side note, while flying, an audible whine would intermittently be heard. The frequency of the whine would change with rpm. I had a lot of concern as to where this noise was coming from. Answer: I removed the short tach cable and it was dry (no lube) on the inside. I added lithium grease and all is well.
Jim Diehl 7A
Free replacement
I have a Vans tach and sender I no longer use. Its yours if want it. Total hours 28 on both units. I now have 2 Pmag and EIC for RPM.
Larry
765-505-1160
Jim and Larry - thanks for the suggestions and offer of parts. It's been going on for a while with longer and longer durations of it dropping to zero so i checked the connectons. Everything seemed tight. The sender is mounted directly to the tach drive with no cable. I found it loose and tightened it. Still was intermittant so ordered both the gauge and sender from vans. Just trying to decide which to change first. Does Van recommend the cable to get the sender away from engine heat? Charlie
What was the outcome of this? My Vans Tach has started reading low and bouncing a little. The gauge is $48 and the sender is $88. I was thinking of starting with the gauge, but don't want to waste my time if the sender is a known failure point... 735 hrs on both.
Sending unit for me, twice. The shaft inside is to long (even if the unit seems loose). Feel the backside of the unit, if there is a bulge on it, the too long of shaft pushes the internal wheel out of alignment with its magnetic pick-up.
I have the proper length of shaft on record at the hanger if you want it I can get it for you. You can order replacement shafts from Van's and they will be various lengths, you have to get it right or it just happens again. Ask me how I know.
500 hrs since I figured it out with no problems.
hope this helps
doug
p.s. if it has reached the point of being intermittent it has stretched the housing and the whole unit needs replaced not just the shaft.
Thanks! I ready your earlier posts on the subject and decided to check that before ordering any parts. I am away from the plane for a week, but will post my findings...
My solution was to purchase a 12" tach drive cable and use it to remotely mount the tach sender on the firewall. Went through two of the senders before realizing they really hated life when directly mounted to the engine. I've got about 250 hours now with the sender remotely mounted on the firewall and its working like a charm.
