aviationgeek84
Hey All,
I was wondering if someone could help a newbie (me) decipher the instructions for Step #8 in the Van's Practice kit (not the toolbox).
The step reads:
To me, as a newbie, it seems like this paragraph has two different set of thoughts in it - one says it's too thin to countersink, the other says to countersink the spar.
Maybe I'm reading too much into it? Probably way easier than I'm making it.
Thanks!
Casey
The step reads:
Disassemble and debur all components. Dimple the remaining holes in the spar, skins and ribs. Dimpling the spar is a special case. It is 0.040" think - a bit thick to dimple well and a bit thin to machine countersink safely. So, we combine methods by dimpling first, then enlarging the dimple with a hand deburring tool. This is done by eye and tested by dropping a rivet in the hole to determine fit. Machine countersink the spar and trailing edge wedge with the microstop countersinking tool.
Thanks!
Casey
