I'm installing van's outboard landing lights which are halogen and would like to have them occilate.Who is making a unit that will make this happen.... The real landing lights are from "Duckworks" Thanks for your help
The aero electric set up is definately the most cost effective way to go,
but if you ever want to upgrade those lights to Xenon, you will need
a different flasher. I orginally had the AE wig wag set up but switched to
this when I upgraded the tip lights. A lot more money, but extremely simple
to wire and works fantastic. Wish I had used the Max Pulse from the beginning.
