Michael Burbidge
I'm planning on a G3X Touch based avionics system. Many of the avionics and other devices, such as the magnetometer, AHRS, AP Servos sit on the CAN Bus.
The standard Van's Harness that ships with the RV-14 support both Garmin and Dynon. But I'm puzzled as to how it supports these Garmin devices that sit on the CAN bus.
As an example, the Van's wiring diagram has pins labeled "MAGNETOMETER/AHRS DATA A, B AND C". But the connectors, and connections don't appear to be CAN Bus compatible.
So I'm wondering if and how the standard Van's Harness supports the CAN Bus?
Michael-
Michael-
