N82VM
About to start my new kit (RV-8) Anyone know what method the vans fiberglass parts are manufactured? Are they wet layup i.e. Heavy with resin or do they vacuum bag their part. A friend of mine does extensive composite work. He was telling me some weight could be saved especially on large parts of they were vacuum bagged vs wet layup. I couldn't find any threads but my apologies if this has been answered
A mixture
My RV6 cowling is epoxy pre-preg fiberglass with nomex honeycomb and urethane foam core. The wheel pants and empennage fairing look like wet layup epoxy fiberglass. The RV6 wing tips are wet layup fiberglass with a gel coat surface - might be polyester resin - it was a while ago and I don't remember the smell :)
Not sure what the pepto bismol colored new cowlings are made from, or how.
Vacuum cured, sandwich cored prepreg is the lightest but a PITA to finish. Wet layup with a gel coat is the heaviest but easier to finish.
2 cents worth
Jim Sharkey
A Change
I may. be out to lunch here....but I understand that Van's has just recently changed their fiberglass (cowlings and wheelpants).....no longer pink cowlings but now gray...and is apparently in response to try and eliminate the pinhole problem.
I haven't seen a cowling, but my empennage parts looked like wet lay up with gel coat.
I was thinking of giving my friend my empennage parts to use for copy. Obviously a time factor but it could be a weight savings. Maybe even less weight required to be added in counterweight material on the elevator tips?
You're not out to lunch. They started green, went pink and now have a gray top surface, and per a discussion at the factory a couple weeks ago that's for the purpose you mentioned.
Just wondering if you've calculated the benefit to this alternative, i.e., how much weight will be saved? Seems like a lot of work to save a few pounds. Most of us could go on a diet and lose more weight than I suspect you'll save. Not meant to be offensive...just an observation. :)
No offence taken! It's another persons curiosity I'm just providing the plug to copy.
As far as weight, I'm committed to certain weight adding luxuries. Finding ways to offset may be a lost cause but worth exploring. I appreciate everyone's knowledge and input..
Currently 6'5" 222 would love to get lean down to 205.
