Status
Not open for further replies.
Daida
Hi Folks!
Does anyone have part list of this FF-Kit offered from Van's?
FF-8 IO-360M1B C/S
I need it because i would have to delete some items as i go for a FP prop.
Van's answer to my question is somehow encoded, i still work on de-code it.
Thanks already!
Daida
got it from Van's
i got the list from Van's direct.
here it is.
1.00 FF-8 IO-360M1B C/S FIREWALL FORWARD KIT
1.00 CT Q-60 QUADRANT CABLE 60"
2.00 CT Q-55 QUADRANT CABLE 55"
1.00 FAB-HORIZ INDUCTION-1 IO-360 180/200 HP
1.00 IO-360 THROTTLE/MIX CABLE ATTACH KIT FWD
1.00 PLASTIC TIE WRAP 5.5? NYLON TIE 70-0108
1.00 VA-136 FUEL LINE IO-360 23?
1.00 PROP GOV MT P-860-4 (I)O-320/360 LYCOMING
1.00 VA-153-PC MT GOV CABLE BRACKET
1.00 BAF-360 BAFFLE KIT
1.00 VA-139 FUEL SUPPLY HOSE 16.5
1.00 AA6-063X3/4X3/4X9? ALUM ANGLE
1.00 AT0-028X3/16X6 FOR F.WALL KIT
1.00 AT6-058X5/16X15 7/8 ALUM TUBE C-610
2.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!!
1.00 FF ? FIREWALL PLUG SS FIREWALL PLUG
1.00 EA LV-1 HEAT SHIELD EXHAUST HEAT SHIELD
1.00 CT A-740 BLACK PUSH PULL CABLE BLACK
1.00 DUCT CBT-5/8 COOLING BLAST TUBE
1.00 EA CV HOSE 9816 BREATHER HOSE 4 CYL
1.00 EA DYNA BOLT BOLT SET 4 CYL DYNAFL
4.00 EA DYNA VI-STD VIB.ISO.ALL EXCEPT-10
1.00 EA EXH 8 IO-360M1B RV-8 MIB W/MUFF
1.00 EA OIL COOLER II O-320/360 OIL COOLER
1.00 ES 24021 STARTER SOLENOID 2OUT
1.00 ES 24115 MASTER RELAY
1.00 ES DIODE MASTER MASTER RELAY PROTECTION
1.00 ES DIODE STARTER STARTER RELAY
1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1.00 FF-705 BREATHER TUBE
1.00 FF-709 OIL COOLER DOUBLER
1.00 IE VMP INSTALL KIT FITTINGS/HOSES
1.00 PT-035X1/4X12 FUEL OVERFLOW TUBE
1.00 VA-102 FUEL PRES. HOSE 15.5
1.00 VA-168 SENDER MOUNT
1.00 VA-133 OIL PRESS. HOSE 27.25
1.00 VA-134 OIL COOLER HOSE 19.0
1.00 VA-135 OIL COOLER HOSE 16.5
1.00 VENT DL-03 2 ? ALUM FLANGE
1.00 VENT SCAT 2X6? SCAT TUBE X 6 FT
1.00 VENT TG-10 CABIN HEAT SELECTOR
1.00 AS3-063X1 1/2X4 6A--8/8A (INCHES)
1.00 AT0-035X3/8X24 SOFT ALUM TUBE
0.50 F AE102-11 FIRESLEEVE $/FT
1.00 EA LW-75444 SNIFFLE VALVE
0.25 EA HOSE H177 IO SNIFFLE HOSE $/FT
1.00 BAG 626-1 FF MISC. HDWRE IO-360
1.00 BAG 627-1 FF MISC. HDWRE IO-360
1.00 BAG 628 FF MISC. HDWRE IO-360
1.00 BAG 629 FF MISC. HDWRE IO-360
1.00 BAG 958 AN426AD3-4 RIVETS
1.00 BAG 991 AN426AD3-3.5
1.00 BAG 1934 AN426AD3-5
1.00 BAG 1935 AN426AD3-6
1.00 BAG 1978 AN470AD4-5
1.00 BAG 1979 AN470AD4-4
1.00 AS3-063X1X12 ALUM STRIP
1.00 CT BEARING HWR, PROP BOLT, NUT, WASHERS
1.00 CT BEARING MW-3M THROTTLE ATTACH ASSEM
1.00 DOC FWF COMPLETE TEXT/DWGS
Status
