Jesse
Does anybody have a wiring diagram or instructions for the "ES Dimmer" that Van's sells? I have one here with no wires and need to figure out how to wire it up. It has "+", L, C and Ground terminals.
Thanks.
Jesse,
I tryed to locate a diagram and could not find one but you could probably bench test it and figure it out. I would guess
+ CONSTANT
Jumper from + to C
L to whatever you are dimming
Ground to airframe
If you do that there SHOULD be no ill consequences if is wrong that I can see. It's just a dimmer with a internal relay that could be fed separately if needed.
Suprised no one has came forward with the wiring diagram though.
I'm pretty sure I have one of these at the hanger, next time I get out there (when this cold spell passes) I can get you the info.
Send me an email to remind me.
