Larry Parham
My 9A has the standard Vans Cowling and a plenum. There is a small air gap all the way around, between the two. How do others mate the two together so they can be detached easily? thanks Larry
Here's a few shots of my plenum. This has taken forever. I hope it works well.
My plane does not have a forward transition piece across from left to right closing off the engine to the top of the plenum.
Wow that is a very extensive plenum arrangement. thanks for pictures It makes sense now
Us there any need to get a tight seal between the cowl and the intake to the carbie. I'me having high temps and wonder if that could be caused by high pressure air below the engine.
