BillL
So I have/had had this pesky oil leak and found the factory shipped the vac cover plate installed without a gasket. It was leaking.
Should I clip the gasket to allow the cavity to drain to the hole on the bottom? Or just install the gasket that covers that drain-back hole?
I am thinking to clip it, so any weeping can drain back to the crankcase.
slbTHGfk5a9aXK3UEhBPOm8iI64sdtu50pgxg_jWCEBnlpa1jPeF8aHRdMigcmFr50R81qno91BwhWq6rL0Vb6WDK9tgCD0WpHTP4uTDA7Nm33x4jQidyaYX9ACcjrFKfI6rbg94-F7_Cco_R1tPH5bMNckT_CTTjgNydK6BiAaialjoNJyeouRLLudjatnzRXXIwo6XrSBnPXmsWcBMndHXrfQlPu5DNH1Nt74Jzh-vzbH83XxYJ5yCZpwnJSRvW90bhHZCjoGzNZvqAQZLEGY5YmPg5Uobavi7LC85L8vpde_I5Ulhu3_o12sAuHD0K5yk2uCifAzDv4rakbtovdJpR5g8_FYdoNUglg9sN6CB-0fnI57jgzXPKN5RUkNlJUshxD9waSa0fg5LtqKG3ZGT-0W-P_rBuL0N7wi749kbVDnlN1s1DAQ-HBizUte5wu7UwaH8f5geiQO9v6jjqRhqM02tf5zyGW0XLztv_4YaGJF6lBIK7M87GXszfEde22eMeFZ7_79I6LWa0kLr02-JcDE4CvldZYgUSvHklbrrqCDZBSKBAJfA3YCfj1jIyeu2n81yQs4oEfsmw1H4JwI2Dc4okwlgBWV6gC3kiqfMjvXr9qC5AwVSNfdSNDk8J6yf9YzzYDvA9EM18FMG_7tmmBCjp3tRgcnpucBo-31KAFRDKMo1q7ZoQ1PrJWg7ItDBH956-msvisu2bhZNL07H=w800
Why not put the cover directly on the accessory housing? BTW, there is a high pressure oil port on that interface, so it needs a non-cork gasket. I can't speak to all variants of accessory housings...
That?s not a drainback hole. It?s the pressurized source for wet vacuum pumps. Just use a gasket as is and bolt on the plate. The splined shaft has a seal, so no worries about having to drain that cavity.
Thanks, I'll just replace my clipped gasket. It's a wonder it did not leak more with the gasket missing.
