Rick RV-4
Hello . . .
Like a lot of folks, I will not be installing a vacuum pump. What plate do I use to cover where the vacuum pump used to go on the accessory case? Anyone have a part number or place to order it from?
If it helps, I have a Lycoming O-360 C2A (a conical mount O-360 A1A).
Thanks . . .
Rick
Parts...
Rick,
Looks like it's a 60430 "Cover, vacuum pump" with a standard 8313 gasket.
If you already have the long studs installed, then four 68593 spacers and 1/4 - 20 hardware (nut, plain washer, internal tooth washer) is also needed.
From an O-320 parts catalog, but the vacuum pumps are standard.
The catalog shows that you keep the adapter assembly on the case - the bit that holds the gear and drive shaft for the pump.
hope this helps.... gil in Tucson
Thanks Gil!
I'm a little confused by what you said about " . . .the catalog shows that you keep the adapter assembly on the case - the bit that holds the gear and drive shaft for the pump".
Can you explain what you mean here?
Thanks again,
Rick
Looks like a spacer
Rick RV-4 said:
Thanks Gil!
Thanks again,
Rick
Rick,
The bit that looks like a spacer about an inch thick, that the vacuum pump mounted on.... gil A
