Hi All,
Wondering if anyone else has noticed, after properly attaching the F-635 Elevator Bellcrank with the required hardware (per the plans) and torquing the AN365-428 nut, have you noticed any (slight) lateral play in the VA-146 Bearing?
I've tried a few different VA-146 Bearings from Van's, and I continue to notice slight lateral play in each bearing.
I've checked the Bellcrank assemblies of a few local flying RV's (on my home field) that were built 6+ years ago, and none of their VA-146 Bearings have any lateral play.
Just wondering if anyone else has had the same experience after installing their F-635 Bellcrank.
Thanks in advance for your replies!
Mike
Mike
