Rainier Lamers
I have uploaded a software update for the V10 radio to www.MGLAvionics.co.za. This update works through a RS232 serial port and the radio interface program that you can download from our website. This Windows program contains instructions of how to apply the update.
This update adds a setup function allowing the suppression of the sidetone in two stages: Suppress sidetone for TX only and suppress sidetone for all functions (effectively disabling the intercom).
This can be used for systems using a speaker and microphone setup to avoid the speaker from feeding back into the microphone.
The second item updated concerns the operation of RS232 serial port 2. Some commands where not accepted on this port in the past. These missing items have been added.
It is recommended that you only consider updating your V10 if you want to take advantage of any new functionality.
V10 radios with a version number before 030209 (date/month/year) cannot be updated using a serial port. These early radios can only be reprogrammed at the factory, however once this has been done, they can therafter be updated via the serial port.
Rainier
CEO MGL Avionics
Rainier
CEO MGL Avionics
