Blain
Working on the draft version of the POH. Would like to insert reasonably close V speeds as a starting point for my configuration.
Anybody care to share what they use for a -8, IO-360 (180), swinging a 72" x 85" Sens?
Speeds
Here is a good start...180 HP XIO360 M1B with Hartzell C/S Prop
Speed ? Solo Weight
Top Speed 204 MPH *____________________
Cruise 75% power @ 8000 ft: 195 MPH *____________________
Cruise 55% power @ 8000 ft: 173 MPH *____________________
Stall Speed: 51 MPH *____________________
Speed ? Gross Weight
Top Speed 202 MPH *____________________
Cruise - 75% power @ 8000 ft: 193 MPH *____________________
Cruise - 55% power @ 8000 ft: 171 MPH *____________________
Stall Speed: 58 MPH *____________________
V speeds
Your speeds are low compared to those published on the Vans site. Do you have wheel pants on your Aircraft? Do you know any other obvious cause for the low speeds?
Bill
The speeds Posted are I similar to my own. Are you experiencing and noting higher speeds. Vans numbers would be in weather ideal for tests.:confused:
V speeds1
My -8 has no gear, intersection fairings or wheel pants and seems a little faster. That's why I asked. It does have 10:1 pistons from Lycon. Have you done the GPS checks to confirm IAS?
