I pulled my cowling to prep for pinhole filling, and noticed that the mixture arm nut hits the lower cowl (AFP injection, Superior cold air sump, IO-360). The nut rubbed through the inner fiberglass layer, but hadn't penetrated the outer skin of the cowl. I was able to re-index the mixture arm aft two teeth, but to gain a bit more clearance want to invert the mixture arm bolt (head down). Normally I know that it's "heads up", but I'm not sure if that rule is set in stone. Thoughts???
Burt
Burt
