Lionclaw
I'm using the Lycoming O-320-H2AD engine on my 9a project, which required moving the oil door to the top/center of the cowl. I knew this would affect the cowl hinge pins somewhat, so I put the break in the upper hinge in the middle (instead of lower/right side).
While doing the final cowl fitting work I'm finding it very difficult to get my hands through the oil door to insert the pins.
The two ideas I have are:
1. Make a removable fiberglass panel at the top/rear/center of the cowl to get at the ends of the pins.
2. Use the pins with welded tabs that Vans sells and insert them from the lower left/right. I could recess the tabs into the fiberglass and use countersunk screws to attach them.
Which would you choose? Anyone have any other ideas?
Here's a pic so you can see my frankencowl
