Joe Parish
Is it possible to upload a flight plan from an iPad with Garmin pilot to a Dynon Skyview? I know you can with foreflight. Thanks Joe
Dynon Avionics said:SkyView can now connect to: Seattle Avionics FlyQ, ForeFlight Mobile, PocketFMS EasyVFR, OzRunways, and SkyDemon iOS/Android apps, via Wi-Fi.
A Follow-up to the follow-up, I upgraded SkyView from 15.0 to 15.2 yesterday, am running Version 6.2 of OzRunways and despite multiple attempts, cannot get OzRunways to share the plan with the Dynon. The hamster-wheel-of-death does its' thing when you press the "Share" button, but that's as far as it goes. I'm in touch with the OzR guys to see what's going on and will report back if/when I get it working.So a bit of a followup - I tried to use this today, and could not work out how to export the flightplan to SkyView in any documentation. The Ipad was connected to SkyViews WiFi dongle, and I discovered and tried the method subsequently described by the OzRunway's folks, but I couldn't make it work. In saying that, I have firmware 15.0, the OzR folks tested it with 15.2, so I can't say if that caused the issue, but I will update SkyView before flying again. The Ipad is running iOS9 and 6.2.1 of OzRunways.
To export your OzRunways plan to SkyView, you need to have a plan active in OzR, press the Share icon in the top right (looks like a box with an upwards pointing arrow) and Dynon SkyView should be available as an option under the Print button.
