Duncan I see you are fairly new and a RV8 interested member. I have to assume a lot about your time, finances, RV flying if any. First of all a RV4 or RV6 with 150HP is likely the hottest plane you ever have flown and may be ever need to fly (I am assuming). Going to 160HP is slightly higher compression O320. Not a big jump in performance as you are already going lioke a scalded cat. 160HP to 180HP not a big difference and you will pick up 30lbs more weight. (BTW there are other options Carb vs FI, fixed vs CS prop). Going to 180HP is a 360 cubic inch Lyc. It is physically (bit much) larger and heaver. Is this a big deal? Well it will be work, just leave it at that. There is enough difference to make it interesting. AGAIN assuming you never built a plane, RV in particular and you will need a hanger, tools, and lots of time and some building talent. Is it like building whole plane no. WEIGHT is a factor if the plane is already heavy and has Fwd CG. You never get a higher HP engine that is lighter. The RV8 your are interested was the first Van's plane MADE for the IO360 angle valve 200HP engine and CS prop. However a 150HP fixed pitch will work. The early RV's 4 and 6 were focused on 160HP and fixed props. Again they are very nice flying, fast, nimble if you keep the weight down. I had a 150HP RV4 I built and I beat 180HP RV's in cross country races. Part of that was race tatics and airmanship but for the most part I was almost as fast or a handful of MPH slower than some 180HP RV's. Part of that it is fit, finish and again weight. I also had a CS prop and ran at 2900 RPM (for race day only). That gave me about 160HP.
It sounds like you are telling not asking. Seems you got it all figured out. Just lets say again assuming money no object het a 180HP or 200HP RV. You will pay for it. Much more likely to get a RV4 with 150HP fixed pitch (again hottest plane you ever flew or likely to fly I assume) for a much much better price (10's and 10's and 10's of thousands). As I state above if you want a PROJECT RV you can rebuild in your dream image then it does not matter. However keep in mind a nice O360 or IO360 is going to cost a lot. The PROP that was ona 320 is not going to work fixed. If CS Hartzell you might be able to reuse on many models of engines and HP.
OK good to know. Do not buy a project plane or one you want to upgrade engine and prop. Buy a turn key. Have fun, fly it, maintain and sell it. The exception is panel. If the bones are good, good engine and prop and has 1990's steam gauge panel then you can find someone to make and install a panel for reasonable (under $20K but can be done cheaper if you don't go over the top with autopilot and dual screens etc.).
Your Zenith Rotax to Auto engine conversion is not relevant. We have been talking about Lyc to Lyc upgrading the HP (usually 320 to 360 or the 235 to 320). Yes obviously huge difference in engines Rotax to some auto conversion (not the least is the actual engine mount, cowl, systems, electrical, cooling, exhaust, intake). Second NOT a fan of any auto engine conversion. I guess they are getting better in the sub 120HP range for slow flying planes. Anything in the 160HP and above Lyc dominates. However auto engine conversions are not significantly cheaper and generally ALWAYS under perform the purpose built aircraft engines. Auto engine conversion reliability is always a question mark, especially PSRU. Weight? Auto engines tend to be heaver. All true.
Yes to answer you buy a Zenith or RV for that mater with the Prop and Engine you will fly for the duration of your ownership is the wise decision. HOWEVER do as you like. With your admission you would have to pay someone to do this work... No don't buy a project. People who work or modify on RV's are not growing on trees. EAB kit panes are not Certified. However some A&P's and shops are starting to cater more to kit planes, there is a regulatory grey area and liability working on these planes as a 2nd party. The ones that do work on RV's or EAB's will charge you a fair price and that is a lot $$$$, because it is so time consuming. They can't starve and will be charging shop hours like it was a Cessna. The point of EAB kit planes is learning not getting cheaper planes than Cessna and Piper. If you have no intent on learning and working on your plane (to your limits with supervision from say EAA Tech advisor) then get a Cessna and pay A&P's to work on it. Finding good independent RV mechanics to do major repair or mod work is not a down the street deal. There are only a handful of them. Again the idea of EAB kit planes is YOU learn.
You really need to research the cost of owning a plane. Hanger, insurance, fuel, oil. An experimental or any GA plane ownership does rely on owner/pilot maintenance to keep cost down, oil change, plugs, brakes, inspectiion, minor repair or replace as needed. Bottom line a 150HP fixed pitch RV (if built light) is a fun high performance time. Good luck. RV prices are through the roof. A nice 180/200HP CS prop glass panel, panted upholstered RV (any model 4 through 14) is going to be well into 6 figures, even mid to high 6 figures today. If you have that money go buy an RV you like, an RV8 with all the bells and whistles and HP you think you need. It should hold the value unless the economy crashes.
