Saville
Hi all,
I'm in the market for a -4 or a -8. There are a lot of variables in my mind and I'm trying to sort them out/eliminate them by getting answers to questions. This particular question is a big one:
There is a "Build or buy?" thread in the -4 forum. The consensus seems to be that if you are going to buy, find a good airframe and then customize it the way you want.
If I buy an a/c with an O-320 FP, and I want to upgrade to an O-360 C/S, the questions are:
1) Is there any difference in the amount of work and/or expense doing this in a -4 vs a -8?
2) In either case, would I need a new engine mount? New cowling? New anything else?
3) Aside from routing the prop control to the cockpit and modifying the throttle quadrant, is this sort of engine upgrade a difficult proposition if you have not built an airplane?
Thanks for any insight.
