Hi all-
I am replacing the plastic brake line in my -4 with -3 braided hose from Bonaco. Original plans show the plastic as a single line from master cylinder all the way down to the caliper. In perusing the forums for info on hoses, all of the pics I have seen show a cockpit line terminating at a bulkhead fitting in the firewall/fuse, then another line continuing from there to the wheel. Just curious if there is a reason why a single line routed through a bushing/grommet is necessarily a bad idea.
Any thoughts would be appreciated.
Eric
Eric
