jeffsvan
New install.
Tee-d into the pitot line to connect AV30.
Trying a simple pitot check with a syringe and
It won't hold air. Remove AV30 and test airspeed indicator alone and it is fine. Leak on AV30?
Rotary knob on AV30 very touchy.
Hard to set altimeter or heading bug.
There is a solid green line on display during boot up and on screen during operation.
See photo.
Anybody else have these issues?
It has latest software 2.1.4
2 of the 3
There is new firmware out for the E that addresses the twitchiness of the center knob. Came out a week or so back.
Make sure the tube is cut square and that the release ring is all the way out and not depressed. I noticed one of my connectors did not fully engage the first time.
As for the green line, I believe that is the sign of a failing LCD.
That green line definitely looks like an infant mortality issue with the LCD. I would contact the vendor and arrange for a return.
Returning the unit and have already received a return shipping label and a refund.
thanks for the help guys. Will purchase a factory new unit ASAP.
