First, RV-9 Dwg 29 (section G-2, upper right corner) says "Notch F652 to clear the attach nuts for C-664 (sliding canopy only, see Dwg 42)." I can't seem to find Dwg 42 anywhere. Is it included with the QB fuse drawings, or is it in the finish kit, which I have not received yet?
Second, Dwg 25 (and the instructions) call for an 8-32 tap to be run through the outboard nutplates for the left and right forward seat floors (F939 & F-940). What would be wrong with running this tap through all of the cabin cockpit nutplates to make them easier to deal with (fwd baggage side covers, baggage tunnel cover, upper and lower baggage bulkhead, etc.)?
Thanks for the help.
Greg
Greg
