Absolutely! The two-piece rear bulkhead and rear floor panel greatly facilitate your inspection of the tail cone area, its contents, and the flaperon actuator components.
Thanks! I have the two-piece rear bulkhead and am about to install the tank, so now's the time to go for the two-piece floor.
The two piece aft baggage floor is intended for the Garmin G3X version. The ADAHRS bolts to a doubler on the left side cover. If it wasn?t two piece, you would have to remove the fuel tank to access the ADAHRS.
