rvbuilder2002 said:Here is a link to an article about why turbocharged engines in the RV-10 are not recommended.
http://www.vansaircraft.com/pdf/hp_limts.pdf
Also, if you do a search in this forum using "turbo", you will find a lot of discussion on the subject.
rcaligan said:What's the Vne on the -10? I've read somewhere 230 MPH, but I can't confirm it.
What altitude does that Vne limit apply to? Sea level? The service ceiling? Somewhere in between?
Is the Vne on the -10 actually IAS or TAS?
