wirejock
Does anyone know if there is a tungsten bucking bar with a hole to use the squeezer dies?
Is it possible to drill mine?
I'm trying various methods (practicing on scrap) to rivet the ribs to the main wing spar. Practice rivets tend to roll just a bit. Vans calls for the manufactured head to be on the rib side. The rivets are 470s and there is no way to get a set in there square. I can almost get an offset set to work but it's not perfect. It seems to be caused by the set. I can hold the gun and set in a position that results in good heads but that position is not an option against the ribs.
Maybe my OCD is kicking in again but I want perfect shop heads.
I thought if I had a hole in the tungsten bar, I could use the squeezer die on the manufactured head and back rivet the spar side.
