RONSIM
Flying for a couple of hours in the RV-10 this week, TT was doing a great job of flying the airplane while we enjoyed the Florida weather. Suddenly, the TT just shut down, like the power had been switched off. I tried resetting the switch several times, pushed all the buttons and no joy. A couple of minutes later, with the switch still "on", the unit fired back up and acted normal. After a couple of minutes, all went dark again. This happened a half dozen times on the way home. On the ground, the unit fires up, but I did not leave it on any length of time. I checked the plug for looseness, and the switch -- all seems good there.
Any suggestions or is it time for the unit to go back for a "New Year" repair job?
Take the backshell off your connector and check for loose pins. Check the grounding point also. Let me know what you find.
Thanks, Lucas
Will do! I did do some wiggling, with no failures, but will do as you suggest.
