rapid_ascent
I'm working on the schematic for my panel at the moment and I'm trying to figure out how to connect up a source select switch to feed the Vizion. Initially I plan to have just the G3X GPS and later on add a 430 or similar.
I have a DP4T switch so I can switch both the RS-232 and the ARINC signals.
I'm assumming that normally I would select the G3X RS-232 interface and let the G3X handle which source it is using. I'm trying to figure out how the ARINC inputs figure into this. Would the ARINC signals go from the 430 to a GAD29 and my switch? Does the Vizion select ARINC if it is present?
