Jesse, thanks much!
(My plane stopped at Dunnellon yesterday, for fuel --- great price!)
Happy New Year --
R.
The ground shown is for the shield if you use a shielded wire, which you don't need to do. Pin 3 to switch, other side to ground.
talk with Lucas tomorrow at trutrakCan anyone tell me if the vizion 385 will allow me to hand fly the pitch while it flies the localizer on an ILS approach?
I used to be able to do this with my digiflight II but I was unable to figure this out today while practicing. Still trying to get used to the new unit.
This would be a great topic/video for one of you GoPro enabled types! I don't know what it is, but I really have trouble pushing the correct button and getting the new AP to do what I expect. I'm either not pressing the round knob enough or I press the wrong one of the three.
I have the round Vizion 385 and Garmin 430 non waas.
Jim
I would suspect if you put the VS to 0 (not altitude hold) you might be able to do this but can't say for sure.Can anyone tell me if the vizion 385 will allow me to hand fly the pitch while it flies the localizer on an ILS approach?
Jim
Jim
Jim
I don't believe it will fly the Localizer. When you turn inbound the 430 will automatically switch from GPS to VLOC because you have to use the Localizer once inside the FAF. The Vizion is only connected to the GPS portion of the 430.
It flies the route steady as a rock on GPSS but on track, it hunts left and right like crazy, 4-5?. Is there a setting to correct this?
TIA,
TIA,
I have this exact issue with a Sorcerer that we haven't been able to figure out.
Lucas, I found the "Gyro set mode" in the manual and I then called Ray Lawrence and asked if he'd done the procedure at installation and he said 'No.' Do you think that if I do this that it might solve the issue?
Best,
