jbDC9
A few months ago I finally installed a used Vizion 385 a/p in my RV-8. It. Is. Awesome. Why didn't I install one years ago?? I have it connected to my 496 GPS (RS232 wire) for nav tracking.
But, here's my issue with it; when navigating to a fix, I usually point the plane in the general direction of the fix with the Track selector, enter "Direct to" in the GPS and then select "Nav" mode on the a/p. The a/p then starts to drift a bit left, very slowly... I monitor the drift on the GPS cross track data block. It usually drifts left to show 200' cross track error, then will hold that steady as a rock. Weird! If I re-enter "Direct to", it does it again, drifts left and holds steady at 200' left of the course line. It also tracks left when on a multi-leg flight plan, so it's not just a "Direct to" glitch.
Any ideas as to what's going on here? Is there a setting in the a/p or maybe the GPS that I've missed? Has anyone else seen this? I'm glad to have basic nav tracking capability, but the offset has me puzzled...
Thanks!
Thanks!
