Pat Stewart
I got my servo back from TruTrak and re-installed it today. They corrected the locking issue and explained how to zero the gyro in calibration mode which worked great (not in my manual). In the setup mode it turns left and right exactly as it should. The remaining problem is the pitch direction. In calibration mode when dialing up a decent it try?s to climb. When dialing in a climb it try?s to descend. Both TruTrak and the manual say to either add or remove a jumper which in my case was remove (just cut the jumper wire). Easy enough however no change. Servo still runs in the opposite direction of the command.
Although I don?t think it?s an issue, the only mod I have made was adding an extra 18? of wire to the harness provided by Stein. I can call TruTrak on Monday but curious if anyone else had experienced this issue.
